somebody can help me?
2014/8/27:21:55:50 DAC DAC-PC === Setup started on DAC-PC by DAC ===
2014/8/27:21:55:50 DAC DAC-PC Path_Length: 155
2014/8/27:21:55:50 DAC DAC-PC Current Directory C:\Users\DAC\AppData\Local\Temp\_AIFCB7.tmp
2014/8/27:21:55:50 DAC DAC-PC Launch
2014/8/27:21:55:51 DAC DAC-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DAC\AppData\Local\Temp\_AIFCB7.tmp\Setup\AcSetup.dll
2014/8/27:21:55:51 DAC DAC-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/27:21:55:59 DAC DAC-PC PageOpen LaunchDialog
2014/8/27:21:56:02 DAC DAC-PC PageOpen LicenseDialog
2014/8/27:21:56:05 DAC DAC-PC PageOpen ProductInfoDialog
2014/8/27:21:56:28 DAC DAC-PC PageOpen ProductSelectionDialog2
2014/8/27:21:56:31 DAC DAC-PC PageOpen FullProgressDialog
2014/8/27:21:56:31 DAC DAC-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Users\DAC\Desktop\Nova pasta\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/8/27:21:56:44 DAC DAC-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
From installation log file, it failed at Windows Visual C++ 2008 SP1 with 1603 code. This maybe because you have a higher version or corrupted VC++ 2008 installed. Please go to Control Panel to uninstall all the VC++ 2008, then rerun the installation.
Hope this helps.
Hi,,,!
I tried this
it fails on x64 and its ok for x86
i´ve uninstalled vc 2008 before.
2014/8/29:17:35:08 DAC DAC-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\DAC\Desktop\Nova pasta\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/8/29:17:35:16 DAC DAC-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/8/29:17:35:16 DAC DAC-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Users\DAC\Desktop\Nova pasta\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/8/29:17:35:32 DAC DAC-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
