Hello All,
Please find attached screenshot of error, my some autocad 2015 files are corrupted.
i read this forum
http://forums.autodesk.com/t5/autocad-2010-2011-2012/open-drawing-errors-found/td-p/3133144
The solution is given in this forum, i can repair corrupted files by given 2 methods.. but the repaired files are showing error again and again, i have to repair it every time.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Q1) Please can you share with us ONE of your "permanently" corrupted drawings ?
Q2 Are you using a "special" version of ACAD like : Cicil, Architecture, MEP, etc ?
Q3) Are you using an other specific application on top of your ACAD ?
If YES, which one ?
Patrice BRAUD
Thanx for reply.
I cant share file here. can you share your mail id for this?
I am using AutoCAD 2015 (not special version) and not using other specific application.
Hello
Ok I sent you a private msg ...
Patrice BRAUD
i hope you checked that corrupted .dwg file.
one thing i have to say..
After repairing and editing again corrupted file is giving that error in some machines but not in every machine. in some machine that 2 methods are working but in some machines not.
The problem is with my machine? Reinstall AutoCAD/Format machine will solve this problem?
Hello
YES your file has a strange corruption coming from Bad Geometry inside Blocks !
Many many errors like >>>
AcDbBlockReference(13055F) scale invalid uniform
Step 1 40300 objects controlled AcDbBlockReference (130694) scale invalid uniform
You can correct with RECOVER and ReSave the drawing but the errors are always here ...
I have used some special routines to purge your DWG but the result was not perfect !
So I save the drawing as R12 DXF and reloading it : no error !
... But a few things have been lost ...
Tests have been done with ACAD MAP 2012 and with ACAD 2014 ...
Patrice BRAUD
