Autocad 2014. I can't see the command line correctly (i've tried hiding and showing with ctr+9 but it doesn't work). When i click the command line, this shows up:
ERROR FATAL: Unhandled e0434352h Exception at 859c811ch
Does anyone know what could it be?
Thanks.
welcome @forums.autodesk.com!
Try to disable your hardware acceleration (command _3DCONFIG ==> manual tune).
Another try: try to move the command-line by clicking (and holding) the mouse-left-key just below the "x" on the left side of the command-line window.
- alfred -
one idea more: change the workspace to any other predefined one (command _WORKSPACE).
- alfred -
I tried all these solutions but they didn't work.
It finnaly appeared doing this: while trying to move the command line, the Fatal Error showed up again. I have the "automatically save" so, when I opened it again, the Drawing Recovery Manager opened too. I don't really know why but the command line showed up again correctly.
The problem is, when I run Autocad, I have to provoke the Fatal Error so the command line appears. And it is obviously not a solution.
I will try uninstalling and installing again.
Thanks for your replies Alfred.
Before you do that you can reset your AutoCAD profile, look to the Windows start menu ==> Autodesk ==> AutoCAD ==> AutoCAD 2014 (or 2013) ==> there you find the option to reset the settings.
Make sure you have saved any customizations before!
If you are asked to migrate settings from any older AutoCAD release ==> don't do that.
Good luck, - alfred -
