AutoCAD 2013/2014/2015
Active Contributor
cpotter
Message 1 of 20 (6,059 Views)
Error 1325 on first startup
6059 Views, 19 Replies
05-29-2012 07:22 PM
I get the following error message when I try to start AutoCAD 2013 as a user.
Error 1325. 'username' is not a valid short file name.
It runs fine as Administrator.
We are on a domain with roaming profiles.
Windows 7 64 bit.
Any suggestions??
Craig
Alfred.NESWADBA
Message 2 of 20 (6,056 Views)
Re: Error 1325 on first startup
05-30-2012 12:56 AM in reply to: cpotter
is it the first time you start AutoCAD with your account?
If you look into the folder C:\USERS ==> do you see your account-name here? Do you have full access-rights within your folder?
Some reports out in the www say you have to update the "Windows Installer" but I would first as the admin, if you can have (for a short test-time) full local admin-rights, then also turn off UAC and try again.
- alfred -
Alfred NESWADBA
Active Contributor
cpotter
Message 3 of 20 (6,011 Views)
06-05-2012 10:59 PM in reply to: Alfred.NESWADBA
Hopefully will have time next week to try "full local admin rights". Will see what happens then. Thanks.
Craig
New Member
sundermannc
Message 4 of 20 (5,624 Views)
10-05-2012 11:19 AM in reply to: cpotter
We are now seeing the same thing on our users.  We have the same setup as you, except we are using folder redirection rather than roaming profiles.  Did you ever find a solution to this?
vmichl
Message 5 of 20 (5,616 Views)
10-05-2012 02:14 PM in reply to: sundermannc
Active Contributor
cpotter
Message 6 of 20 (5,599 Views)
10-07-2012 04:23 PM in reply to: sundermannc
Sorry, no we havn't yet found a workable solution. Currently we are still using 2012.
Craig
Active Contributor
cpotter
Message 7 of 20 (5,596 Views)
10-07-2012 04:26 PM in reply to: vmichl
vmichl wrote:
Try the following tip:
http://www.cadforum.cz/cadforum_en/msi-error-1325-username-is-not-a-valid-short-file-name-tip6686
Vladimir Michl, www.cadstudio.cz
We are certainly going to look into this as an option.
Craig
New Member
sundermannc
Message 8 of 20 (5,532 Views)
10-12-2012 08:40 AM in reply to: cpotter
Just to update future readers of this thread, this solution did work for me.  Thank you!
Active Contributor
cpotter
Message 9 of 20 (5,500 Views)
10-15-2012 09:01 PM in reply to: vmichl
Finally got time to try this and it was successful, thanks very much. :smileyhappy:
Craig
Member
mkillinder
Message 10 of 20 (4,066 Views)
08-13-2013 12:26 PM in reply to: cpotter
But how did you "copy" the registry entries?  I dont understand how to just insert that info into the registry.
thanks,
matt
