When ever i right click the mouse with an object selected or no object selected it will always repeat the last command. Here is how i have my right click customization setup.
Is there any setting anywhere else that can control this? I have already reinstalled AutoCAD.
What happens when you check on "Turn on time sensitive right-click"?
I have this problem too, I use the sensitive right click set to 150ms but I can hold it for ever and on relese it envokes the last command.
It was working and I have the same set up at work and my work pc is ok.
I have been meaning to post this as I wondered if anyone new what file holds these settings and could I take the working file from my work pc and replace the one at home.
What happens when you 'quick' right-click?
The right-click menu should appear with 'time sensitive' on.
EDIT: My problem is only on selected objects with nothing selected the default menu works ok it is just the Edit menu that is affected.
Quick or Long right click is just repeat last command I put the sensetivity to 500ms with no joy I also tried a new mouse incase it was that. I have tried everything I can think of apart from a reinstall which I dont really want to do if I can help it.
I can get it so right click brings up the default menu on selected objects but thats it.
So i turned on the delay and it is working better. With the delay i get the menu i need and when an object is selected the correct menu comes up. A quick right click still hits enter however.
Ok I think we have the same problem.
Nothing Selected...
The sensitivity only has effect on the default menu with nothing selected. A quick right click is for repeat last command and a long right cick should bring the menu default menu up.
With Selection...
a Quick right click should bring up the edit menu and a long/hold right click will allow free move of the selected object for quick copying/block making.
attached is my setting and everything works fine on my work pc but not on my home pc, both using 2015.
Here are the settings that I have, and it works the way you stated.
Think its going to be a reinstall, I have searched a lot for this problem and this is the closest I have got to someone else having the same problem.
Which really indicates the problem is probably me 🙂
