I have a drawing that does not show edits until a regen is issued. It is just a dwg made up of xrefs in modelspace and text/dims in paperspace. If I am zoomed to extents and erase an object or edit it all is fine. As soon as I zoom in to edit or erase, the object remains until a regen is issued. Regenauto is on. What is happening?
@dmmeehan wrote:I have a drawing that does not show edits until a regen is issued. It is just a dwg made up of xrefs in modelspace and text/dims in paperspace. If I am zoomed to extents and erase an object or edit it all is fine. As soon as I zoom in to edit or erase, the object remains until a regen is issued. Regenauto is on. What is happening?
Video card driver up to date? -PURGE and or AUDIT recently?
Yes,yes & yes. Also, cannoscale checked as well as scalelistedit. This is only happening in one file. Not sure if a "by drawing" variable has been altered or if the file just has some kind of bug in it. It seems display related but, like I said, other drawings are working fine. Even other files that use the same base xrefs are fine.
@dmmeehan wrote:Yes,yes & yes. Also, cannoscale checked as well as scalelistedit. This is only happening in one file. Not sure if a "by drawing" variable has been altered or if the file just has some kind of bug in it. It seems display related but, like I said, other drawings are working fine. Even other files that use the same base xrefs are fine.
Post your problem dwg.
