Did AutoCAD 2015 remove the ability to edit multi-leaders AND dimensions with the MTEDIT command? I can only find the double-click method of editing each object’s text. It would be nice to keep to the keyboard method I am used to by hopfully changing a setting somewhere? Thanks for any help!
Solved by kkohlhoff. Go to Solution.
Apparently TEXTEDIT works on all of these objects still, so I just changed my PGP file alias so that I can still use the keyboard.
