AutoCAD Forum
Editing block and closing the whole drawing by mistake without saving
6 REPLIES 6
516 Views, 6 Replies
Hi
I dont know how many times i have been editing a block in a drawing and then clicked on the cross. Instead of closing the block editor i closed the whole drawing, many times without saving.
It should have been made impossible to close the main drawing while editing a block!
Yours sincerely
Stefan Emhjellen
6 REPLIES 6
leothebuilder
I have done the same thing many times!
nrz13
A workaround to avoid the interface confusion is to use keyboard shortcuts for exiting the block editor.  I use "SB" and "DB" for "save block" and "discard block changes" respectively.  Here's the LISP:
(defun c:SB ()(command "bclose" "s" "regen")(princ))
(defun c:DB ()(command "bclose" "d" "regen")(princ))
Note:  the drawing automatically regens after exiting the editor.  The second regen I added was to fix layer order issues after exiting the block editor.  If you don't have that problem, you can remove the "regen" part.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
leothebuilder
in reply to: nrz13
I use the keyboard 95% for all commands.
I guess you could add the BCLOSE command to the .pgp file as BC.
I like your solution because it adds the "save" command.
Thx
in reply to: leothebuilder
Jepp.  i have to change this bad habbit and use BK shortcut  for closing blocks
(Still i wish Autodesk could change this  "trap" )
 BC !
leothebuilder
Way way back up to around release 12 or so END would end your autocad session.
There were so many times I tried to enter END for osnap and it would bomb me out ot autocad.
Fortunately they Autodesk changed that.
”Boost
