Is it a bug, or am I missing something? If you have a VP color asigned to a layer and you edit single line text on that layer by going into modelspace thru the viewport, the text reverts back to its modelspace color. It does not do it with MTEXT and moving or copying the text doesn't change it. The only way I've found to change it back is to change the color in properties and the change it back to by-layer.
Solved by pendean. Go to Solution.
Thanks for the answer. I guess it must be the video card. Changing from layout to model and back had no effect or a REGENALL, but saving the dwg and closing and reopening does. Probably not a big enough problem for IT to update my computer though
Changing the cache mode from all layouts to last layout did the trick. REGEN works now.
thanks for the help.
