AutoCAD Forum
EDIT copy command in Auto Cad 2015
3 REPLIES 3
JaywantJadhav4586
781 Views, 3 Replies
I am not able to use EDIT copy command in Auto Cad 2015. it's giving error " Copy to clipboard faild"
The file contents diffrent layers with diffrent elevations & also few blocks. when I copy single object it's work fine.
I am using Auto Cad Civil 3D & it's under subscription.
3 REPLIES 3
You might want to post in the C3D forum.  Subscription has no bearing here.
pendean
in reply to: JaywantJadhav4586
Why don't you ask for help on the Subscription Page? It's what you're paying for... .
doni49
in reply to: justshutup
Unless OP is trying to copy C3D elements (such as featurelines, surfaces etc), then I'd say that the Acad forum would be correct.
OP:  As Dean suggests, since you are on subscription, I think you'd be wise to open a support ticket.
You noted that you're on subscription but that fact should have no bearing on what's causing this issue.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
”Boost
