I am not able to use EDIT copy command in Auto Cad 2015. it's giving error " Copy to clipboard faild"
The file contents diffrent layers with diffrent elevations & also few blocks. when I copy single object it's work fine.
I am using Auto Cad Civil 3D & it's under subscription.
@JaywantJadhav4586 wrote:I am not able to use EDIT copy command in Auto Cad 2015. it's giving error " Copy to clipboard faild"
You might want to post in the C3D forum. Subscription has no bearing here.
Unless OP is trying to copy C3D elements (such as featurelines, surfaces etc), then I'd say that the Acad forum would be correct.
OP: As Dean suggests, since you are on subscription, I think you'd be wise to open a support ticket.
You noted that you're on subscription but that fact should have no bearing on what's causing this issue.
Don Ireland
Engineering Design Technician
