Hi guys, fairly new to Autocad so there is probably a simple answer to this
When making pipe juntions (for this case 2 connecting pipes at 90deg to each other, is there any way to remove the inside section of pipe where the two connect and trim accordingly?
I have been copying the whole section then solid subtracting the different pipes then seperating solids, removing the sections i dont need and then putting back together.
This works fine however when it comes to adjusting angles or inverts i need to create a whole new section and re do this process.
Any suggestions would be greatly appreciated
Cheers
Cheers
http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%208.pdf
