when I use the 3d rotate command on solid objects, sometimes I get the helpful gizmo that displays and allows you to select the different axes of rotation....and sometimes it doesn't come up. How do I make it come up if it is off??
I will email a free tasty beer and bag of cheetos to the first genius who tells me how!!
thanks!!
Solved by tkelleher. Go to Solution.
