i installed autocad 2014 and when i can open autocad show this errors and close. erros are changing. but always first one shown.. i search the internet but i cant found solution. i deleted all autocad files and install again but not solved.. I need help. Thnx a lot.
Hi Umutcan,
Welcome to the forum!
Have you activated the product? There is an issue with AutoCAD 2014 activation, and the error message looks like yours.
Try to check this knowledge base: usa.autodesk.com/getdoc/id=TS21825687
Hope this helps,
i cant activated product because of these errors. Download at autocad offical page and i installed then i double click icon autocad show these errors so i can join my activated code. So that only i donwload and installed i cant open. However i try this solution. i can write the result of this solution.
Thnx for answer but i found solution. Only i killed the "OneKey Lenovo" Task with the Task manager. And autocad opened. Thnx a again.
Hi Umutcan,
Thank you for the update. I'm glad that you fix the problem.
Apparently this is a known issue: http://usa.autodesk.com/getdoc/id=TS20682850
