Hello All,
I have a dwg files that contained 5 dynamic blocks. Block A, B, C....
I want to separate Block A, B, C...by separate dwg file. What is the best way to do this?
I tried to wblock block A out, but i don't think this method is work, because i don't want the block inside one dwg file, i want it to be independence dynamic block. Any suggestion how to separate these dynamich block?
Thanks much,
Dennis
Your question is very confusing.
You say your have a drawing file(s) with 5 dynamic blocks and you want each block in a separate file.
You tried Wblock and mention that you don't want the block in one single file?
