Can anybody explaind How can I constrain two circle's center points and have them move along the same arc with a rotation parameter?
I am trying to create a dynamic block of a robot for planning and want the arm and end efector to rotate independantly but have the end efector "follow" the arm rotation.
Block is attached if anybody wants to try.
I already have the two separate rotation parameters defined.
Solved by pendean. Go to Solution.
Thank you. I have moved the question there and was provided a solution.
Thanks again for the direction.
