AutoCAD Forum
Dynamic Blocks - Constraining movements
2 REPLIES 2
JCard
447 Views, 2 Replies
Can anybody explaind How can I constrain two circle's center points and have them move along the same arc with a rotation parameter?
I am trying to create a dynamic block of a robot for planning and want the arm and end efector to rotate independantly but have the end efector "follow" the arm rotation.
Block is attached if anybody wants to try.
I already have the two separate rotation parameters defined.
JCard
Electrical Designer
Logical Systems, LLC
2 REPLIES 2
pendean
in reply to: JCard
Dynamic blocks have a dedicated forum: http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
JCard
in reply to: pendean
Thank you. I have moved the question there and was provided a solution.
Thanks again for the direction.
JCard
Electrical Designer
”Boost
