AutoCAD Forum
dynamic block to change both sides of a rectangle via lookup list
1 REPLY 1
j_washbourne
297 Views, 1 Reply
Hi all, I was wondering if you can help me. I'm trying to create a dynamic block that would change both sides of rectangle without changing is centre position/insertion point in the model space. I've manged to use the stretch actions on both sides by dragging, but only one sides changes from the centre point not both, another problem I can't get the block to work with a lookup even though ive already assigned value to each parameter in the property box. I'd appreciate any comments you may have. Thanks in advance
1 REPLY 1
steven-g
in reply to: j_washbourne
Make the parameter center based (look in the properties) and then apply a stretch to both ends, if you post your block someone will be able to see what is going on with the lookup.
”Boost
