Hi
I have a simple dynamic block for a break line with one dynamic parameter called "length". I want to use this inside a lisp routine which allows me to do the following
While I am able to create a lisp routine to draw break line by manually asking for size of break, I would like to do it in a way that I can visually size the break point by using the dynamic block. I have also included that lisp routine along with the block for the dynamic break point.
I can insert the dynamic block using the parameters from 5 to 7 but dont know how to modify the lenght parameter from within a lisp routine.
Please help
You're likely to get a better response by asking this on the Autolisp board. There is a larger concentration of people who speak lisp over there so the pool of people who can help is bigger.
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Don Ireland
Engineering Design Technician
