AutoCAD 2013/2014/2015
New Member
0 Kudos
Post 1 of 4
Dynamic block in action does not reflect test block
214 Views, 3 Replies
01-24-2013 05:20 AM
Greetings.
I am in the process of fixing one of our dynamic blocks. It's a fairly simple fix where there was a typo in one of the names of our items in the lookup that needed to be fixed.
I changed the name of the item in the lookup table. I went and did the test block and it seemed to work fine, but when I bring the block into a drawing, it reverts back to the old lookup as if I did nothing at all.
I made sure that the path was correct and I even just dragged and dropped straight from Windows Explorer to no avail.
Does AutoCAD keep referring to the old block? Did I forget to change something else?
Thanks.
A "Purge" of the block in your drawing before you bring it in again should do the trick.
262 Kudos
Post 2 of 4
Re: Dynamic block in action does not reflect test block
01-24-2013 05:25 AM in reply to: asidarta
Hello
Have you tried a BATTMAN or ATTSYNC command to resynchronize the new definition of the Block ?
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
*Pro
138 Kudos
Post 3 of 4
01-24-2013 05:58 AM in reply to: asidarta
New Member
0 Kudos
Post 4 of 4
01-24-2013 07:03 AM in reply to: asidarta
I tried BATTMAN and ATTSYNC but I think those are only useful if my dynamic block had attributes.
Purging the block worked!
Thanks to you both.
