AutoCAD Forum
Dynamic Block clipped boundary doesn't work as expected.
7 REPLIES 7
Message 1 of 8
3wood
1375 Views, 7 Replies
I found an interesting dynamic block. It has a clipping boundary  but you can drag the 'leg' out of the boundary. How can I make such block?
See attached dwg file.
7 REPLIES 7
Message 2 of 8
pendean
in reply to: 3wood
The dynamic blocks forum may be a better location for you to ask/repost in:
http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
Message 3 of 8
Charles_Shade
in reply to: 3wood
Not having used Clipping Boundaries what makes that unique about the DynBlk?
In my LT this looks and behaves as I would expect (except for the extra non assigned Actions).
Message 4 of 8
3wood
in reply to: Charles_Shade
The sample block has a clip boundary as shown in red dotted line below:
To my understanding, everything should be constrained inside the block clipping boundary.
But in this sample, you can drag the stretch grip point toward right hand side and the section symbol will be beyond the clipping boundary, as shown in the next image.
If I remove the clipping boundary, and assign it a new clipping boundary, it becomes normal, ie. the extended 'leg' is properly trimmed at the clipping boundary.
It looks strange to me.
Message 5 of 8
Charles_Shade
in reply to: 3wood
Ahh, thanks for the explanation.
Could it be a Draw Order thing that the DynBlk is on top?
The only item that I can see that is odd is are the different types of Frames (IMAGE, PDF, DWF, DGN, ...) are set to different variables (0,1,2)
Otherwise I cannot see the Clip wwhile in the BE yet it will move with the DynBlk when the DynBlk is moved.
Message 6 of 8
skintsubby
in reply to: 3wood
3Wood
Isn't it just a case of the clip is turned off? Just type "Clip". Then Select the block. Then "On"..
Mark
Message 7 of 8
Charles_Shade
in reply to: skintsubby
That's it. Thanks for helping me understand how the Clip works.
Message 8 of 8
3wood
Thank you. I've never tried setting clipping boundary 'off'.
It's great to learn.
”Boost
