AutoCAD Forum
Dyn Block Visibility Not Working
2 REPLIES 2
sbrusco
548 Views, 2 Replies
Hi All,
I created this very basic dynamic block with two visibility states for which the correct objects turn on/off while in the block editor, but not when i use the "Test Block" option.
After inserting it into a blank drawing or viewing in the "Test Block" option, all objects are visible in the "Transverse Bent" state as they should be, but when i change the visibility state to "Flat" there are two attributes that should be invisible but remain visible. What did i do wrong and more importantly, how can i fix it?
TIA,
Sal
2 REPLIES 2
Light_Guy
in reply to: sbrusco
Lock the position of your attributes. Once I did that, your block worked fine for me.
Paul Hamor
"Always good ships!"
sbrusco
in reply to: Light_Guy
Thanks Light Guy,
That did it. I don't understand why, but that did it.
Sal
”Boost
