Dear All,
As discussed in another topic, i used DXFOUT as below to reduce file size. It works well so I want to create a script for that.
SaveAs the DXF file back into a DWG file.
The problem is when we use dxfout, it will export to a DXF file but still open DWG file. It means we have to open that DXF file to fix. Cannot use 1 script to do that.
I try thi script to save as to dxf, save as will open that DXF automatically and continue with purge, audit but the file size not change.
saveas
dxf
16
-purge
r
n
audit
y
saveas
2007
y
I think the problem is the different between saveas and export. Please advise.
Thanks.
Last time i got the problem with file size then i used DXFOUT to fix that. The process is DXFOUT first then open DXF file for purging, auditing then save back to dwg.
If we purge, audit first the file size is still big.
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Empty-CAD-file-18MB-in-size/td-p/3937947
This is the previous topic relate to file size. I use DXFOUT and fix that file. The problem just appears when somebody copy elements from the bad file. Please see this topic also http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Copy-Paste-multiple-drawings-ignore-AEC-o...
