Hi All,
So I am working with Autocad 2014 and I have literally 100's of detail drawings I have to plot as a pdf. Also, in each drawing I have to insert a file path field. Now, the thing is I know exactly how to do all of that, but I am wondering if there is a faster process, other than going into each drawing one at a time and inserting the field and plotting the pdf which is a very time consuming task.
thanks in advance!
Solved by Patchy. Go to Solution.
Thanks for replying guys, and yes that makes sense. So, what I'm trying to do is make a PDF detail book from over 100 autocad dwg details. Each one has to have there dwg file location path written underneath it. The file path is there so that I can immediatly locate that drawing in whatever folder it is located in when Reference that PDF. So I've figured out how to use Publish, but I still have to insert the dwg file path in each drawing.
thanks!
