I am trying to Make PDF from DWG using Plot option but it does not make, can you tell me the possibilities where are the problems.
thanks
Means what? Does it bring up an error message, what does the plot log say, when you turn off the sysvar BACKGROUNDPLOT, does that make any difference?
Maybe thousands, beginning with defect dwg-file, defect "DWG to PDF.pc3" file, wrong plot scale and/or paperformat, you searched in the wrong directory for the resulting file ... please don't mind that, but we don't know you, so also users can be sometimes the source of the problem too.
You might search through posts with problems creating PDFs, when you have more infos or you can upload the drawing (and screenshots with your plotsettings) we can look into that settings and see what we can do to isolate the problem.
- alfred -
I am getting this message
Attempting to cancel sheet: Model
Please can you suggest the solution.
If that is the message you get: "Attempting to cancel sheet: Model"
Then what have you tried from >>>that search results<<<?
- alfred -
