AutoCAD Forum
Drawing Utilities > Drawing Properties
21 REPLIES 21
Message 1 of 22
sbrusco
10499 Views, 21 Replies
Hi All,
If we're in a drawing and pick the AutoCAD application button > Drawing Utilities > Drawing Properties we can, and do, use this to enter custom propterties. Is there any way to print out a report of a drawing's custom properties? Ideally, i would like to be able to select multiple drawings and print a report of each drawing's properties.
I think i'm looking at some custom programming but before i go down that rabbit hole, i want to know if that wheel has already been invented.
TIA,
Sal
21 REPLIES 21
Message 2 of 22
dbroad
in reply to: sbrusco
Have you tried creating a block with field attributes pointing to these properties?
Architect, Registered NC, VA, SC, & GA.
Message 3 of 22
sbrusco
in reply to: dbroad
Thanks for your response dbroad,
I have not,because there are no "standard" formats used. It is really an odd way that we're using this, certainly NOT how anyone would have guessed, we're using it to track updates. For example, for the custom prop "Name" we're putting the updaters initials and the date (seb 13073) and the "Value" is a brief description of the change (Added shim attributes to the fastener tags for all support fasteners)
Any other ideas?
Sal
Message 4 of 22
Volker_C
You may want to consider using a Table with Fields linked to the DWGPROPS.
-Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
Message 5 of 22
sbrusco
in reply to: Volker_C
Thanks Volker,
That is a good idea for going forward, and I'm sure there are MANY better ways for the future.  But the problem today is collecting the history of our library and this is how someone, years ago, decided to track updates.
Sal
Message 6 of 22
TerryDotson
If you were to consider third party software, take a look at ToolPac's Drawing Catalog tool.  It allows you to simply navigate to a folder and it will display the DWG files in that folder (along with the drawing thumbnail).  You can control the columns of the report and include any DWGPROP fields (including custom properties).
Message 7 of 22
sbrusco
in reply to: TerryDotson
Hi Terry,
Good option but we will soon be implementing Autodesk's Vault so it will track and catalog our future work. But I'm still looking for something to report our past.
Sal
Message 8 of 22
hmsilva
Sal,
just the custom properties?
Henrique
Message 9 of 22
oohaah
in reply to: hmsilva
Try the express tool Propulate.
You can list the properties of drawings in a folder and sub folder in the text window by selecting the scroll method. Copy the history and paste into a word doc.
Message 10 of 22
sbrusco
Hi Henrique,
Yes, just the custom properties. But i like oohaah's suggestion except that when i use the "List" option on a directory, i can't find the list. I suspect it is saved somewhere but i don't know where.
Sal
Message 11 of 22
sbrusco
in reply to: oohaah
Hi oohaah,
I like your suggestion except that when i use the "List" option on a directory, i can't find the list. I suspect it is saved somewhere but i don't know where. Can you give me more help with this? I checked the help file but it was no help.
Sal
Message 12 of 22
oohaah
Hit f2 to bring up the text window. It will be in the history of the command line. There is an option to copy history.
Craig
Message 13 of 22
sbrusco
in reply to: oohaah
Thanks for the very fast response, oohaah.
I can find the results in the history (F2) if i do a single, current drawing but not when i choose a directoy.
Sal
Message 14 of 22
hmsilva
Sal,
a quick one, creates a file. txt with the name of dwg and custom properties, try it is minimally tested...
Hope that helps, good luck
Henrique
Message 15 of 22
oohaah
That's how I did it. I'm sorry I am not at my computer as it is 10 pm where I am!
Craig
Message 16 of 22
sbrusco
WOW!
Henrique, you are wonderful.
Thank you sooooo much.
Sal
Message 17 of 22
hmsilva
You're welcome, Sal
Glad I could help
Henrique
Message 18 of 22
sbrusco
Hi Henrique,
Can you be bothered once more please.
What do i change this line to if i want to save the TXT file to my desktop? The drawings i'm reporting on are in a directory that is read-only to me. I'm pretty certain this is the line that should change.
(setq DwgList (vl-directory-files DirPath "*.dwg" 1))
TIA,
Sal
Message 19 of 22
hmsilva
Sal,
Change
(setq TxtFile (strcat DirPath "DWG-Properties.txt"))
to
(setq TxtFile "C:\\Users\\yourusername\\Desktop\\Properties.txt"));; you have to see if the path is correct, and change "yourusername"
Henrique
Message 20 of 22
sbrusco
Hi again,
This works fine but i thought there was some code that would find out the path to the desktop of whatever user was logged in at the time. But this works for now and THANKS AGAIN.
Your help has saved me lots of time.
Sal
”Boost
