AutoCAD Forum
Drawing Templates
3 REPLIES 3
Kevin_UK
691 Views, 3 Replies
Drawing Templates
Hi All
What would the best way to go with regards to drawing in Meters or Millimeters.
Set up 2 different templates one for Meters and another for Millimeters each with there own Text Styles, Dimension Style, Multileader Style and Table Style!
At the moment I have a template set up for millimeters with annotive Text and Dimensions.
Regards
Kevin
3 REPLIES 3
Bob_Zurunkle
in reply to: Kevin_UK
Maybe. I have a template drawing for multiple types of equpment, and another for a specific group of equipment. Without the second one, I'd be removing the same drawing tabs for every similar project!
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
skintsubby
Kevin
We use both mm and mtrs.
We have only one template, it's set to mm with all the styles we need. We draw everying in Modelspace and annotate in Paperspace (or model tab and layout tab for the newbies 🙂 ) when we use metres, we just change our units... ...
Mark
Kevin_UK
in reply to: skintsubby
Mark
Thank you for that, that sounds brilliant, never thought about doing it that way. I will give that a go.
Kevin
”Boost
