Hello Forum:
I have a set of 4 drawings that i believe are bound (as they are 30mb), which to my understanding means the XREFs are all within the file. If i open the file i can see the MANY layers that i have now turned every one ON. There is still tons missing from the drawing. (I have an older revision PDF that shows what is missing).
The weird part is that if i try to open the file in autocad, the preview window shows all of the missing things....
Yes, all of my layers are on, yes ive selected all in the layer manager window
Yes, all XREFs are loaded except for 3(which are just logos, and i have proof they are from other files from this client)
Yes, the issue is with model and paper space layouts
Yes, i ran an AUDIT, and there were no errors with the file.
I'm using AutoCAD 2014 on a Windows 7 64bit machine.
Why would so much of this drawing be missing?
Solved by macreadhead. Go to Solution.
Have you hit F2 and read the command history of what all happened while the file was loading? Have you checked the XREF Manager to see if it still believes there are unbound XREFs? You say you turned all layers on, but have you thawed all layers? What happens if you play with the quickselect tool?
Don't put too much stock into the "preview". That is just a snapshot at the last save (probably, but not necessarily). Reference files can be moved or deleted, startup routines can make changes to the drawing before it's displayed at opening, etc.
Do you have DWG Trueview installed? If so, open it there to rule out any startup code making changes.
Back in AutoCAD after you open it, immediately run the "U" command, and repeat until there are no more undos available. Any change?
Erase everything visible, then run the DBLIST command? How many objects are still in the drawing?
If you can't make any progress, can you ZIP and post the drawing here?
PROBLEM SOLVED!
So, it appears that part of the drawing is from Civil3D, and since i do not have the addon to be able to view those entities, i was unable to see most of the drawing.
Thanks for your help! This was really frustrating to figure out....
hello sir,
IN THIS FILE MORE ELEMENTS & ELECTRICAL CIRCUITS ARE MISSING....CAN U PLEASE SOLVE THIS ISSUE...THANK YOU SIR
