AutoCAD 2013/2014/2015
Active Contributor
Elliottam
Message 1 of 3 (955 Views)
Drawing lines at specific angles
955 Views, 2 Replies
09-11-2012 07:27 AM
If I am drawing in 3D and I want to draw a line with a specific angle, how do I choose the plane that it is drawn in? Cos whenever I specify an angle the line is drawn in the horizontal plane
*Expert Elite*
pendean
Message 2 of 3 (951 Views)
Re: Drawing lines at specific angles
09-11-2012 07:43 AM in reply to: Elliottam
You want to draw a line in a 3D environment? What angle, X, Y or Z?
And where exactly do you wish to start this line?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
*Expert Elite*
dbroad
Message 3 of 3 (919 Views)
09-11-2012 10:42 AM in reply to: Elliottam
1) If you are working in the primary orthogonal plans, turn on ucsortho and then use the view command or the naavcube to make whatever view you want current.  The ucs will automatically rotate to that plane.  You still might need to set the origin before working.  Saving UCS's helps.
2)If you have solids, then UCS face works well.
3)DUCS mode can help.
4)The suggestion about the selectable UCSICON works too.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
