Hi all,
Since last week I noticed that the drwing/file tabs only shows two drawings when I have more than two open drawings in the AutoCAD session. is there a way to show more than two tabs?
I know there is an icon to show a list of the drawings opened in the session, but I rather navigate on tabs.
Thanks all in advanced
Johny D.
I'd comment on the thread linked below, which seems to be the same issue you are reporting. Maybe there will be some things you have in common that will help determine a cause to the problem.
http://forums.autodesk.com/t5/autocad-2013-2014-2015/number-of-files-in-files-tabs-seems-to-vary/m-p...
Hi all,
I don't know how but the file tabs are working again. Last week I still had the same problem but yesterday it worked fine.
What happened? I don't know but it is working now.
If some one know the solution, please make it public.
Thanks all for your replies.
Johny D.
