I got a drawing from the surveyor and the cursor is not aligned to the UCS World view but to the north direction on the survey drawing. How can I change the Cursor orientation to be othographic to the view?
Solved by Patchy. Go to Solution.
Thank you! One more question. I think the drawing was done in 3D and I just need a 2D drawing. I keep snapping to points that are in the Z direction. How do I change that?
