Hi all,
I was drawinga alot of lines with the help of the pointer that stuck at the end of the line and after taht it stuck at the begining of the other line (i hope you understand what i mean). I dont know what i pressed but now this function is not active and is verry difficult to draw the lines.
Any help?
Thank you in advance!
best regards,
Dimitar Georgiev
Solved by nestly2. Go to Solution.
Solved by Neil47. Go to Solution.
Not sure this is the right answer but are you talking about Object Snap endpoint? Osnap can be toggled on and off with the F3 key or enter osnap on the command line to get drafting settings dialog box up
