When I start the setup, an error message pops up saying download was interrupted ....that communication between my computer and Autodesksrever was lost. Any ideas? I attached the error message widow as well.
on the download-site you have the option to start the setup directly or "Download only", use the second option and when the download is finished you can start the setup from the local exe-file.
Good luck, - alfred -
The AutoCAD download is 1.6GB. I would not recommend trying to install from the web.
Instead, download the file to your harddrive, then launch the setup file. If the download doesn't work from the page you were using, try the Virtual Agent instead. (make sure you select the correct AutoCAD release and version.)
