Hi There,
I most likely have a very simple problem or solution to my problem..
I am trying to make my current blocks more dynamic. I got a block for an aluminium flat bar, although i have one for 2mm, 3mm, 4mm etc. i want to reduce the amount of blocks to 1 high dynamic block. I would like to have two lookup functions. 1 to choose thickness and 1 to choose the possible width for the chosen thickness.
I know this is possible with multiple lookups if im right i just need some directions where to look i think.
Many thanks!
-Patrick
You can use as many lookup tables as you need. They can access all your parameters, but it does take some pre-planning to get things working right. Here is a block of fabricated steel angle that uses a bunch of lookups to control it.
