When I go into CUI & try to customize the double click for say line & set it to bring up the properties box it works, but it changes all double click actions to do that unless there is already a default double click for a particular command. When I set the double click in the hatch command to edit the hatch (hatch box pops up) it works but it will change the line double click to do the same thing. I don't remember having this problem in 2009. I'm saving in the CUI every time I try this.
I must be doing something wrong. Any help would be great.
Ashby
I'm guessing you are not replacing the command found in the double-click under hatch, you are actually redefning QUICK PROPERTIES to HATCHEDIT command instead.
That's your mistake. Open the Command List in CUI and drag HATCHEDIT to be under the Hatch entry for double-clicking and remove QP. After you fix/put back Quick Properties definition back correctly. See attachment.
PenDean - I found your post today, 3 years later.
I believe I understand the procedure to modify the double click (in my case to get full properties on a double clicked line). I have two questions before I mess anything up:
1. There are two 'properties' listed in the CUI I can drag. How do I know which one to pick and drag?
2. You mention to remove (delete) the QP after dragging the Properties under 'Line', and then to put QP definition back correctly. What is the proper way to delete the QP and does 'put back' mean dragging QP off the list back up into the Line double click folder?
Your screen shot is good but does not answer my above questions.
Thanks for your help in the past and hopefully for this one. Harry
