Does anyone know of any drawing-specific settings that would disable double-click editing?
I should mention that we actually have DBLCLKEDIT set to off and we handle the event with our own code. It's working on all but one or two drawings and i can't figure out what's different betweent them. The command line is returning "Invalid Input"...
Well my first thought is there's something wrong in your code and without seeing the code, I can't tell you WHAT that is. Without seeing your dwg files, "the difference between" them could be just about anything.
But if you're getting Invalid Input messages, then my first guess is that you're double clicking something that the codes isn't set up to handle.
What element type is this?
Don Ireland
Engineering Design Technician
I am having the same issue. No double clock edit on well nothing. Also, my right click context menu not working regardless what my right click settings are under user settings, but it will work say within the Mtext editor. Also, when i select say a hatch pattern my ribbon would react, now notthing.
Just a guess on my part...Check you 'pickfirst' variable. ensure it is set to one. Been caught with this once or twice.
cheers.
