AutoCAD 2013/2014/2015
Active Member
eerdogan
Message 1 of 5 (371 Views)
Does "Cloud sync settings" work?
371 Views, 4 Replies
12-08-2012 12:44 AM
Because apparently it behaves very faulty with me. I have my settings in my PC, like PGP shortcuts, user preferences, etc. When I logged in another machine, which is a clean install btw, I expect that my other machine's settings will come here. But it is the opposite. My original machine gets default shortcuts, etc. Very very frustrating.
Any ideas how to use this properly?
Emre.
rkmcswain
Message 2 of 5 (344 Views)
Re: Does "Cloud sync settings" work?
12-09-2012 04:25 PM in reply to: eerdogan
I only have experience with that feature right after 2013 was released, so I don't know if a SP or hotfix has been released to fix it, but as you describe, the workflow of the sync settings was questionable to say the least.  During my testing, the wrong settings were freqently applied -- good thing this was not in a production environment for me.
You might look at the available SP and hotfixes to make sure there isn't an update before pursuing any further.
Product Support
luconceicao
Message 3 of 5 (317 Views)
12-11-2012 08:59 AM in reply to: eerdogan
Hi Emre,
I am testing this tool now.
I changed the background color in model space and enabled "sync settings".
I then get a message asking me if I want to use my local settings or my online settings.
Have you ever seen this window (attached)?
If I then choose to use online settings, it asks if I want to restart AutoCAD now or later. It then applies the settings saved online.
Make sure that you haven't hidden messages: go to Options > Ssytem tab > Hidden Messages Settings > see if there are any related messages being hidden. If there are, check them to be showed.
Let me know if this helps.
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Active Member
eerdogan
Message 4 of 5 (303 Views)
12-12-2012 01:50 AM in reply to: eerdogan
Thanks for the answers,
After deselecting and reselecting at the new pc,it asked me that.
But here at the work pc, it was deselected after the errors. Now I re-enabled it, changed the backgorund color. But it did not ask me anything. I think it is not very reliable.
Product Support
luconceicao
Message 5 of 5 (294 Views)
12-12-2012 08:00 AM in reply to: eerdogan
Had you made any changes to the work PC before?
What happens if you disable the option, change something in the new PC, then change something in the work pc and enable the sync.
Does it show an option?
