AutoCAD 2013/2014/2015
Active Member
0 Kudos
Post 1 of 4
Does AutoCAD support multiple lines of vertical setting on mtext?
492 Views, 3 Replies
01-15-2013 12:21 AM
I guess it does NOT support it because it seems that it does NOT work properly .
For example, in case of multiple lines of “Horizontal” setting, it works properly like followings.
But in case of multiple lines of “Vertical” setting, it does NOT work properly like followings.
Configure of “Horizontal”:
ABC
DEF
GHI
Configure of “Vertical”:
ABC DEF GHI
In my perspective, it should go downward like followings.
In my “perspective” of Vertical”:
A
B
C
D
E
F
G
H
I
P.S.
We are making application software for importing DXF file from AutoCAD.
If AutoCAD does not support multiple lines of vertical setting on mtex, our software also should not support it, I think.
I want to know the specification for multiple lines of vertical setting of AutoCAD.
This behavior is documented in the AutoCAD help:
About Vertical Text Support for Asian Languages - Note the behavior of True Type fonts that are prefixed with @.  In this case, the font has to be designed specifically for vertical use and the Vertical effect would not apply.
Text Style Dialog Box - Look under Effects - Vertical.
Active Member
2 Kudos
Post 2 of 4
Re: Does AutoCAD support multiple lines of vertical setting on mtext?
01-19-2013 04:35 PM in reply to: EE_Z
AutoCAD does support multiple lines of vertical text, but only when the text style supports it.  If the style does not support it, then it will display exactly as shown in your attached image.
TrueType fonts do not support Vertical orientation, but several of the .SHX based fonts that come with AutoCAD do support it (romand.shx, romans.shx, etc).
Use the STYLE command and browse through the list of available fonts and you will notice that the checkbox for Vertical is only enabled for the .SHX fonts that support it.
Active Member
0 Kudos
Post 3 of 4
02-07-2013 09:25 PM in reply to: Wartherd
Hi Wartherd,
Thank you for your great help!
By the way, is this phenomenon mentioned by any manual.
Unfortunately I could not find it.
If you know it, please tell me
Active Member
2 Kudos
Post 4 of 4
02-09-2013 08:49 AM in reply to: EE_Z
