sometimes when tracing over scanned images I find it necessary to scale non uniformly to restore proper aspect. This was easy under acad 2008 and older by using the block editor. Now that I'm using acad 2013 there only seems to be the dynamic block editor which at least appears to be a more complex tool to use and one I haven't any experiance with. Is there some way to invoke the classic simple block editor or will I have to bite the bullet and find some tutorials on the dynamic block editor?
Solved by pendean. Go to Solution.
There was no third party add on, as I recall when you pasted as a block or invoked the bedit command you got a dialog box offering a number of options among them being seperate x and y scaling. in acad 2013 the bedit command takes you to the dynamic block editor.
Thanks for your reply with clarification to the previous, also correct reply. I tried block from the insert pull down menu and it worked. I also tried per your suggestion invoking insert directly from the command line. I will now be able to use this method to scale x and y simultainously and correct the rotation as well.
Just wanted to add that you can change the x,y,z scales after the fact pretty easily from the properties palatte. Just type "properties", select your block, & type in the fields.
