In Autocad 15 I am now unable to keep the properties window docked and opened at the same time. The default is to auto-hide and does not offer an option to keep it pinned open. WHY? Is there a work around? Why limit options like this when you change versions?
Solved by nrz13. Go to Solution.
Just to clarify, the button the red arrow is pointing to below is not working for you?
This is DOCKED and does not hide:
This is NOT docked but it is ANCHORED and can hide if I turn that on and move my mouse away:
Which matches your screen? they are different.
No problem! Easy fixes are always nice.
