hi
yes it's again and always me !!!
i understand nothing:
i am drawing in 3d model with line tool and i m writing in the command my distance, longer 3 for example but i haven't 3 like i wrote, i ve got a small distance. so i don't understand, and unity of my draw is good, it's in mm, so ... i don't know.
Solved by nestly2. Go to Solution.
Perhaps the line is actually 3 units long, but since you're working in 3D it appears to be shorter because of the direction and/or the view? Open the Properties Palette and select the line. What is the length?
