AutoCAD 2013/2014/2015
Member
Voin_sveta
Message 1 of 5 (181 Views)
displaying the number of the entry block
181 Views, 4 Replies
12-25-2012 09:59 AM
In block attribute manager i can see the number of instances of the selected block in the current drawing. Can I set this value in the field?
tcorey
Message 2 of 5 (160 Views)
Re: displaying the number of the entry block
12-26-2012 08:55 AM in reply to: Voin_sveta
You could do this by creating an AutoLISP variable that stores the number of blocks. Your field could reference the variable.
(setq blknm (getstring "\nEnter Block Name: "))
(setq ss (ssget "x" (list (cons 0 "INSERT")(cons 2 Blknm))))
(setq sslen (sslength ss))
Have the field reference the variable sslen. This will not update automatically when additional copies of the block are inserted. You would either have to run it manually or put it in acaddoc.lsp so it loads with each drawing you open.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Member
Voin_sveta
Message 3 of 5 (142 Views)
12-27-2012 03:16 AM in reply to: tcorey
i created file %name%.lsp
with code
"(setq blknm (getstring "\nEnter Block Name: "))
next i used command appload for load this file.
and now i have lispVariable only blknm.
tcorey
Message 4 of 5 (129 Views)
12-27-2012 01:13 PM in reply to: Voin_sveta
You should also have SSLEN. I have attached a lisp file that works correclty.
Tim Corey, Owner
Redding, CA
rkmcswain
Message 5 of 5 (125 Views)
12-27-2012 01:47 PM in reply to: Voin_sveta
If you can't or don't want to use lisp, another option would be to create a DataExtraction table. The Quantity cell will update (semi) automatically like a field.
