Hello Guys,
Good Morning,
I'm new user of AutoCAD 2014 software, my question is in classic window, when i started to set the icons that i want to see in may classic windows, so that there was a time i want to use the 3D modelling windows. After i use it the that window, i go back to my classic window, i see all icons that i already setup is gone, and back to the default of autocad classic window, how i can save as default my customized window, when i switching the windows even i use drafting & annotation, 3d modeling, 3d basic, and autocad classic. Please help me!
Thank You!
Solved by nestly2. Go to Solution.
"Classic" / "3D Modeling" / "2D Drafting" etc are all different workspaces. If you change the layout of a workspace, you have to save those changes before you leave the workspace or they won't be retained. Assuming you're using the Workspaces toolbar at the top left, there is an option in the drop down box to Save the workspace manually, and/or change the default behavior so changes are saved automatically.
