Hello everybody
I just changed computers and upgraded from Autocad 2011 to 2014 and from Wndows 7 to 8.
No problem installing, or opening files, or working in working space, but when I switch to presentation, everywhere I have the curser passing, the last image appears.
here are some picture.
my graphic card is Nvidia Ge Force GT 740M, version 347.25
can anyone help me because it is impossible to work with that !
thanks in advance
Solved by braudpat. Go to Solution.
Turn off the OPEN GL on the graphic card, your graphic card is not recommend.
if you turn off, its solves your problem... and wait for new drivers
Hello
Welcome to the Autodesk/AutoCAD Forums
1) For ACAD 2013/2014 (very important for 2015), you must have "modern" drivers !
And for NVidia cards, drivers have to be from Automn 2014 or later ...
2) If you have an ACAD 2014, have you installed the SP 1 ?
Patrice BRAUD
Hello Marie
Thanks for the Kudos (compliment) !
But please the solution was ?
- New driver for your NVidia GT 740 ?
- SP 1 for ACAD 2014 ?
- or Both ?
Thanks for the Info !
Patrice BRAUD
