Hi,can anyone help me with my drawing. Im using autocad 2013. The solid hatch im using cannot be print. The shadeplot options is locked. Ive tried fill, fillmode. Tried to copy it in a new drawing, one day it comes out the next day nothing again and i have to redo again. 😞
welcome @forums.autodesk.com!
The same drawing and same hatch? Or different drawings and/or different hatches.
Are you always use the same printer-/plotter-driver? Have you tried to plot to PDF (just to see what another driver is doing with your graphics)?
A basic option as always is to look if you have installed the current servicepack for your AutoCAD.
- alfred -
hi FloraSor,
you better check the layer you use for the hatch pattern is it printable or not, it might be also on your plot style setting...
hope this will help you..
Virgilio Benedictos
Its the same dwg, same file, same plotter. If i create different new file. Its seems to be ok. But that file, hatch cannot be read. However if use other computers everythings ok. Ill try checking the servicepack.
Thanks for the reply.
already solved my problem, i keep searching and ends up in ribbon panel and gave me idea. My hatches i think are all in the back order. So i tried using the hatch in front and got it properly fix in printing.
Thanks guys.
Thank you for your feedback!
- alfred -
HI
THANKS FOR YOUR FEEDBACK,,,
CAN YOU GIVE US KUDO? HEHEHEHHE...
done 😉
