AutoCAD 2013/2014/2015
Active Contributor
smiddleton
Message 1 of 6 (14,338 Views)
Disable Autodesk 360
14338 Views, 5 Replies
05-24-2012 05:47 AM
Does anyone know if there is a registry setting (or some othere way) to disable Autodesk 360.  My users have no reason to use this feature and I don't want them wasting time with it.
rkmcswain
Message 2 of 6 (14,329 Views)
Re: Disable Autodesk 360
05-24-2012 06:39 AM in reply to: smiddleton
Interestingly enough, you can uncheck this feature during an install, or later using "Add/Remove" features, but even after I removed it - I don't see any change - it is still present in the Open dialog, in the Infocenter, and in the Options dialog. Obviously a bug or someone mistakenly listed it as a removeable feature and it isn't.
The Autodesk 360 FAQ specifically says you cannot uninstall "Autodesk Sync", a component of 360. Not sure if they mean the whole 360 component or not.
pendean
Message 3 of 6 (14,305 Views)
05-24-2012 10:20 AM in reply to: rkmcswain
As a test, I have turned off the "ADSync" and "AcCloudManager" in Windows from starting with Windows, and turned off the 'enable" and "sync" cloud features in OPTIONS. Not seeing a way to hide it all from view though either.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
SteveChestnut
Message 4 of 6 (14,256 Views)
05-25-2012 11:15 AM in reply to: pendean
Hello Dean,
Could you please give more detail on how you turned off ADSync and AcCloudManager in Windows from starting in Windows.  I'd like to do the same thing and don't know how to do this.
Thank you,
Steve
Product Support
Mlgolf
Message 5 of 6 (14,042 Views)
07-12-2012 02:17 PM in reply to: smiddleton
Hi smiddleton,
I accidentally saw this post, and thought this may help.
Please let us know if it did.
Martin Langolf
pendean
Message 6 of 6 (14,018 Views)
07-13-2012 05:22 AM in reply to: SteveChestnut
You can uninstall Autodesk Sync in Using Windows' own Uninstall feature.
I used a freeware called CCLEANER for the test above.
