AutoCAD Forum
dimensions jump to 0,0,0
5 REPLIES 5
425 Views, 5 Replies
Using AutoCAD 2010, dimensions setup for Architectural, modified dimensions using a prefix.  When I dimension a drawing, as I'm working in other areas I notice some of my dimensions are jumping to 0,0,0.  For instance if I dimension something at 5'-10" all of a sudden it might become 138'-5" depending on where the original dimension was put in relation to 0,0,0.  Does anyone know why this might be happening.
5 REPLIES 5
pendean
Are youa ctively snapping to the objects you are dimensioning, or are these floating dimensions (which is what you are describing)?
Paperspace or modelspace dimensioning?
kcobabe
I believe it will also do this if an Xref goes MIA as the dimension is reading to something in the XREF that no longer exist.  So it's attaching to the text string at the insertion point.  Of course this is assuming you have xrefs in said drawing.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
in reply to: pendean
I am snapping to intersections, endpoints, center, etc of the
objects in modelspace.
in reply to: kcobabe
No xref's are involved.
nestly2
Are the dimension in Modelspace, or Paperspace?
”Boost
