I see some dimensions (one ordinate dim for the middle hole does not point extactly to the center of the circle).
But what is the question you are asking or you having problems?
- alfred -
Hello Alfred,
Thank you for your quick reply. Please refer below:
A: As you can see from the drawing I used one of the corners of the bracket for my X-Y zero points (origin) To find the width of the bracket I assume using the OD dim minus the ID dim would give the bracket size. Thickness I can add on later.
A: My main question is as follows, could a machinist create a part with the dims I'm showing now on the drawing? Or am I missing something to make it easier for them?
Never designed a bracket of this type.
BR
KenJG
Something doesn't make sense here?
And missing dimensions for the holes and fillets.
Hello JD,
Thanks for the quick reply.
I did not add other dims since those are pretty straight forward. My main concern was the hole locations and bracket dim (radius etc). I am not sure if the origin I used is correct. All other drawings I ever did where just retangler & full circular type parts, never of this type with an arch & holes.
Hello sir
Kindly help , i need to show the X,Y Coordinates (in single command & same line like (55,85) for the particular point.
But i don't know how to do it.pls help anybody
Thanks in advance.
Babu
