AutoCAD 2013/2014/2015
Valued Contributor
ajohnson
Message 1 of 7 (995 Views)
Dimension text disappearing when selecting dimensions
995 Views, 6 Replies
11-15-2012 07:14 AM
In AutoCAD 2013, when I try to select a dimension object for moving, erasing, &c, the text disappears. Any idea how to get it to stay displayed?  Seems to just be when using AutoCAD 2013.
Alfred.NESWADBA
Message 2 of 7 (977 Views)
Re: Dimension text disappearing when selecting dimensions
11-15-2012 12:42 PM in reply to: ajohnson
can you upload that drawing (at least these dimension and it's base object) so we also can try to select the object?
- alfred -
Alfred NESWADBA
Valued Contributor
ajohnson
Message 3 of 7 (974 Views)
11-15-2012 01:12 PM in reply to: Alfred.NESWADBA
Here's a drawing file.
I think I figured out the cause (but not the soluion, well maybe I've got one). When textmasking (Text Fill Color) is set to background, the text disappears. This could be a change from 2012 to 2013 or it could be because I have an older graphics card.
I checked on another machine with a different graphics card and the text doesn't disappear.
I need a new machine anyway.  Hey Boss....
Alfred.NESWADBA
Message 4 of 7 (971 Views)
11-15-2012 01:30 PM in reply to: ajohnson
same to me, opening your drawing and selecting any of the dimension does not result in text disappearing.
The difference may be that I have installed SP1.1, have you installed it also?
And yes, it may be the graphics card or driver, to make it easier for your gc try if the same issue araises if you have disabled the hardware acceleration (command _3DCONFIG ==> manual tune)
- alfred -
Alfred NESWADBA
Valued Contributor
ajohnson
Message 5 of 7 (970 Views)
11-15-2012 01:40 PM in reply to: Alfred.NESWADBA
I did try with and without the hardware acceleration.  Same thing.
Probably time to go talk to the boss.  He has the same graphics card as I do, but 2013 isn't offical in the office yet.
Alfred.NESWADBA
Message 6 of 7 (963 Views)
11-15-2012 02:20 PM in reply to: ajohnson
just to make sure: have you installed SP1.1?
For you and your boss if SP1.1 repairs the issue: better then investing into a new computer maybe to invest into your salary :smileywink:
- alfred -
Alfred NESWADBA
Valued Contributor
ajohnson
Message 7 of 7 (961 Views)
11-15-2012 02:27 PM in reply to: Alfred.NESWADBA
I wish.
Anyway SP1.1 is on the machine.
