Hi all,
I am extractiong the data form my blocks in CSV file with the dataextraction function, but the problem is that my block is located at lets say X,Y(10,10) and in the CSV table shows X,Y(40000,40000). Someone can help me how to solve this?
Thanks in advance! Any help will be appreciated.
Best regards,
Dimitar Georgiev
Solved by Patchy. Go to Solution.
Solved by steve216586. Go to Solution.
Hy
you are sure that you use the right Fields and nit once scale once coordinates ?
cu cw
Type UNITS on command line and see what it shows.
All i want to determine is the units they are using for the drawing.
-DWGUNITS will show the current drawing unit.
for the size also the reference block
Click on the block, go to Properties and look at the scale X,Y,Z
Zip the drawing and attach it, if you can't fig. it out.
-DWGUNITS does't show the current information. It is an interface to select drawing unit preferences. It doesn't even show defaults.
